LPCxpresso CR V5 Flash commit erro
Content originally posted in LPCWare by cwpjr on Tue Jan 15 16:51:33 MST 2013
I had been merrily debugging a project with the Code Red V5 8k eval version for the NXP LPCxpresso 1114/202 board when all of sudden target reporting write failure/error and tool reporting flash commit error.
FAQ says power issue. Not here. Nothing has changed.
FAQ had a link for a LM Flash utility - No Utility here and directions seem to be for a board with a rest switch so N/A.
Unplugged board from USB, restarted system, checked drivers, all fine.
Went back to example project that I had target debugged - Blinky - and same errors.
How to fix this?
