LPCXpresso jtag
LPCXpresso jtag
1,357 次查看
lpcware
Content originally posted in LPCWare by aferrari on Mon Jul 27 07:55:59 MST 2015
Hello everyone,
I'd like to use LPCXpresso with lpc4078 ARM Cortex-M4 MCU.
Do you know what kind/model of jtags are supported by LPCXpresso?
Thanks in advance.
Alberto Ferrari
5 回复数
1,316 次查看
lpcware
Content originally posted in LPCWare by aferrari on Mon Jul 27 09:35:29 MST 2015
Thanks again for your kindness.
Alberto Ferrari
1,316 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Jul 27 08:53:00 MST 2015
No, Windows XP is not supported. v7.9.0 now introduces support for WIndows 10...
The last version of LPCXpresso that we tested on XP was 7.0.2.
1,316 次查看
lpcware
Content originally posted in LPCWare by aferrari on Mon Jul 27 08:44:58 MST 2015
Dear Support and miccio,
thank you very much for the reply.
Yes I was talking about the Debug Probe. Thanks for the hints.
Another question if you can answer in this post....
I've downloaded the latest LPCXpresso release (7.9.0_455).
It was written that LPCXpresso may continue to work on Windows XP, even if WXP is no longer supported, but when I started the installation the following error arises:
"This program does not support the version of Windows your computer is running"
Could you tell me the latest LPCXpresso version that I can use with Windows XP?
Thanks a lot
Alberto Ferrari
1,316 次查看
lpcware
Content originally posted in LPCWare by miccio on Mon Jul 27 08:12:31 MST 2015
ciao Alberto,
this board here http://www.nxp.com/demoboard/OM13038.html comes with a built in debugged which is allegedly compatible with LPCXpresso.
If you would rather have an external debugger, here's the LPC-Link 2 http://www.nxp.com/demoboard/OM13054.html :)
1,316 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Jul 27 08:05:17 MST 2015
I assume that you are asking what types of Debug Probe is supported by LPCXpresso?
Basically, you need something that supports CMSIS-DAP, such as LPC-Link2, Ulink-ME, Ulink-Pro etc.
LPCXpresso also supports some older style adapters, including LPC-Link and Red Probe+.
