LPC1347 read/write to EEPROM
833 次查看
lpcware
Content originally posted in LPCWare by masterboy on Wed Mar 13 11:15:45 MST 2013
how can I read/write to in-build eeprom on LPC1347? Does the simplest way exist?
807 次查看
lpcware
Content originally posted in LPCWare by masterboy on Wed Mar 13 23:33:56 MST 2013
This is only way? If I understood correctly, in-built EEPROM is a part of flash memory in MCU?
807 次查看
lpcware
Content originally posted in LPCWare by wrighflyer on Wed Mar 13 13:26:29 MST 2013
You use IAP commands 61 (write) and 62 (read). See chapter 21 in the 1347 datasheet (UM10524).
