Delete Key stops working
1,452件の閲覧回数
lpcware
Content originally posted in LPCWare by capstone on Fri Jul 11 16:41:08 MST 2014
LPCXpresso v7.2.0 (Build 153) - Win 7-64 - LPC175x-6x - LPC Open v2.10
Sometimes while performing many edits, the DELETE key stops working.
When this happens, the Right Click/Cut still functions normally.
I have noticed this with v6.1 as well, but do not recall this issue with the Code Red v5 IDE.
A Restart of the Workspace does restore the DELETE key functions.
Has anyone else noticed this behavior?
5 返答(返信)
1,443件の閲覧回数
lpcware
Content originally posted in LPCWare by PJanhonen on Sun Aug 24 11:54:52 MST 2014
Thanks that was it.
Restore defaults in Preferences-General-Keys window solves problem.
1,443件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Sat Aug 23 08:45:55 MST 2014
Have you changed any key bindings? Perhaps accidentally?
1,443件の閲覧回数
lpcware
Content originally posted in LPCWare by PJanhonen on Fri Aug 22 02:03:23 MST 2014
No.
Restarting IDE or whole PC not fix the problem.
1,443件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Aug 22 01:52:53 MST 2014
Does restarting, as mentioned by the original poster, 'fix' the issue for you too?
LPCXpresso Support
1,443件の閲覧回数
lpcware
Content originally posted in LPCWare by PJanhonen on Fri Aug 22 01:33:59 MST 2014
I have same problem.
I installed LPCXpresso v7.3.0 [Build 186] , but problem stays.
Delete key works well in notepad and others editors.
