ISP uuencode help
ISP uuencode help
936 次查看
lpcware
Content originally posted in LPCWare by gudushen on Mon Apr 30 12:12:39 MST 2012
Can someone explain how to use ISP commands to program NXP chips?
I am having trouble understanding what exactly is being written.
For example, i try the following using hyperterminal:
[COLOR=Red]W 268439552 4[/COLOR]
0
[COLOR=Red]CATS[/COLOR]
[COLOR=Red]4[/COLOR]
1
[COLOR=Red]R 268439552 4[/COLOR]
0
$ATS@45%1
516
Why does the read gives me weird letters? it also seems to give more then 4 bytes?
Any help is greatly appreciated, an example would be best.
918 次查看
lpcware
Content originally posted in LPCWare by NXP_Europe on Fri May 04 07:12:18 MST 2012
You didn't mention which chip you are working with, but there is an interesting app note on ISP
http://www.nxp.com/documents/application_note/AN10986.pdf
Hope you find it interesting.
Kind Regards,
918 次查看
lpcware
Content originally posted in LPCWare by researchinnovation on Wed May 02 04:34:25 MST 2012
@Gudushen...Hi...!!!
Can you please share more information about your NXP chip and project and the code which you are  using.
Thanks & Regards....:)
