Debug code too large for license
1,646 次查看
thomaswatson
I appear to be experiencing the issue described here with LPCXpresso 8.2.2 on macOS Sierra 10.12.2. I completely reinstalled the program by deleting the LPCXpresso directory in /Applications/, /Users/Shared/NXPLPCXpresso/, and my workspace. I then reran the installer and activated according to the directions but the issue is still present. The NXPLPCXpresso directory and log file is attached.
Original Attachment has been moved to: NXPLPCXpresso.zip
1,313 次查看
lpcxpresso_supp
We can't replicate any problem here on our macOS 10.12.2 installs.
Whilst we check out your license files in more detail, please can you also:
  1. Post the text from the IDE menu "Help -> Product Information"
  2. Post the build log for the project you are trying to debug : https://community.nxp.com/message/630853
  3. Post the debug log from your debug session that fails : The Debug Log
Can you also confirm if this is an activation you were previous using successfully (potentially on an earlier version of macOS) or did you generate your serial number / activation code after installing Sierra and have never made it work?
LPCXpresso Support
