Coding in assembly for LPC812
2,672件の閲覧回数
SunTzun
Hello. Is there a route to write code for LPC812 fully in assembly without any automatied compilers?
Preferably, if this can be done through an IDE without manually confuguring the linker.
3 返答(返信)
2,659件の閲覧回数
SunTzun
Do any guides or examples for assembly coding for this microcontroller exist?
2,624件の閲覧回数
ErichStyger
Specialist I
Not for LPC812 (don't have that one), but for LPC845:
https://mcuoneclipse.com/2023/05/21/creating-a-gnu-assembly-only-project/
I hope this helps,
Erich
2,666件の閲覧回数
ErichStyger
Specialist I
Yes, you certainly can do this using the GNU as (assembler) (https://en.wikipedia.org/wiki/GNU_Assembler). But I still would advocate that you are going to have the ld in the mix, as it simplifies all the memory mappings.
