Coding in assembly for LPC812
SunTzun
Hello. Is there a route to write code for LPC812 fully in assembly without any automatied compilers?
Preferably, if this can be done through an IDE without manually confuguring the linker.
SunTzun
Do any guides or examples for assembly coding for this microcontroller exist?
ErichStyger
Specialist I
Not for LPC812 (don't have that one), but for LPC845:
https://mcuoneclipse.com/2023/05/21/creating-a-gnu-assembly-only-project/
I hope this helps,
Erich
ErichStyger
Specialist I
Yes, you certainly can do this using the GNU as (assembler) (https://en.wikipedia.org/wiki/GNU_Assembler). But I still would advocate that you are going to have the ld in the mix, as it simplifies all the memory mappings.
