what j5 connector has to be removed for flashing the embedded wizard code
1,654 次查看
suraj78725
hi, i am suraj,
why j5 connector has to be connected while dumping the code to the board via the mcuexpresso directly to access the gpio or common programs and removed while flashing the code via embedded wizard.
with regards
suraj
4 回复数
1,597 次查看
suraj78725
hi zhang,
thanks for your response.
with regards
suraj
1,645 次查看
vicentegomez
Would be possible that you tell us the board that you are using or the device
1,637 次查看
suraj78725
hi
i am using lpc54628 nxp development board
thanks
1,605 次查看
ZhangJennie
J5 is Audio line input jack. It should not affect code download.
Is this issue related with a specific project or SDK demo code? or a common issue for all project?
Please specify how I can reproduce your issue on my side. I will check it.
Jun Zhang
