sd1 using SDK 2.10.1 dev_msc_disk_bm_SDIO
4,906 次查看
iblades_dan
Hello everyone,
I'm trying to bring up the dev_msc_disk_bm_SDIO example on my customer hardware with two SDMMC devices (MCU is LPC55S69 with one SDMMC device connected to SD0 and one SDMMC device connected to SD1).
If I use SD0 (g_sd.hostPort = 0), the card initializes properly, it enumerates to a PC and the PC can read/write SD0.
If I try the same for SD1 (g_sd.hostPort = 1), SD1 does not initialize successfully.  Instead the example code times out waiting for a kSD_Inserted event, even though there's a card in SD1.
Anyone have any insight into this issue?
DanL
标签 (3)
4 回复数
4,887 次查看
iblades_dan
Hi Alice, thanks for your quick reply!  Attached is a screenshot of the example I've imported.
Can you clarify what you mean by "other configuration?"
Best,
DanL
4,877 次查看
iblades_dan
Hi Alice, a quick update - I got SD1 working properly this evening.
Support for SD1 was only partially implemented in the example driver, an area I'd like to see NXP do better.
Implementing a driver function in "bits and pieces" often makes it harder to identify what's needed.
DanL
4,845 次查看
Hello DanL,
OK, thanks for your sharing and suggestion.
Alice
4,897 次查看
Hello iblades_dan,
How about other configuration?
And does the demo " dev_msc_disk_bm_SDIO "  under SDK? Is it the whole name? I haven't find this demo.
Alice
