problem with PRINTF()
2,117 次查看
Nadia
Good afternoon,
I'm using a LPC54616 and I have a problem, I put the instruction PRINTF, and I don't get anything out of the console, I have chosen the Newlibnano library (semihost) and I have taken the floating point, I don't know what happens.
If someone has had a similar problem and knows how to solve it, I'll thank them.
Greetings
4 回复数
2,101 次查看
gusarambula
Hello Nadia,
Would you please check your settings in accordance to  the following Knowledge Base document and let us know if it helped?
https://community.nxp.com/t5/MCUXpresso-IDE-Knowledge-Base/MCUXpresso-IDE-and-Semihosting/ta-p/11164...
Gustavo
2,090 次查看
Nadia
Hello, thank you very much for your quick answer, I have everything set up as a semihost, and I can't print anything on the surrounding console.
2,085 次查看
converse
Senior Contributor V
If you want to use semihosting, use standard C printf() and not the PRINTF macro.
2,076 次查看
Nadia
Hello, thank you very much for responding.
I'm using printf().
