lpcxpresso lpc1853 bin file is too large
742791535
1.after build the project,i get hex and bin files.the hex file is ok ,but the size of bin file is up to 16M.
2. i use lpcxpresso 8.2.2 ide, and lpc1853 mcu.
3. my config is below,could you tell me how  to config my projgect? thanks ,i will be waitting.
converse
Senior Contributor V
See this (old) forum question:
https://community.nxp.com/thread/420872
742791535
the link dosent give me a way to solve the problem.my question is that the bin file make by xpresso is too large up to 16MB,it's not the correct size.
converse
That’s the point. You can’t solve it (with a single bin file).
If you need bin files, you will need to creat two (or more) bin files - one for each non-contiguous memry region.
