lpc804-Deep sleep mode
Sathiya_T
hi,
 here am using lpc804, follow the POWER MODE SDK example package the controller  is work in  deep sleep mode and i cant able to wakeup using wakeup pin interrupt register.using PORT0-5 has reset pin its wakeup properly, but in PINT  interrupt was not working . please be guide the wakeup process using pin interrupt method in deep sleep mode and power down mode
Hello @Sathiya_T
Does the demo code can't wake up through pin interrupt?
What about your board? LPCxpresso804-EVK board or custom board?
Alice
Sathiya_T
hi,
am using LPC804 custom board with 33 pin  and using pin interrupt  but does not wakeup
Hello @Sathiya_T
Share your project, I help to check on my side.
Alice
