lpc1768 RTC Can't Set time but oscillator seems ok
1,098 次查看
Content originally posted in LPCWare by internav on Mon Feb 09 16:32:01 MST 2015
lpc1768 revA  Can't set the time, it just keeps changing.  The oscillator, OSCF flag is not set.  Configured  RTC oscillator output on pin P1.27 and seems stable on scope and correct frequency.  I have 2 other pcbs and have no problem.   Bad CPU?  Noise on power?
1,067 次查看
Content originally posted in LPCWare by R2D2 on Tue Feb 10 16:31:45 MST 2015
Quote: internav
...it just keeps changing...
Test mode  :quest:
1,067 次查看
Content originally posted in LPCWare by embd02161991 on Tue Feb 10 15:56:14 MST 2015
Have you used the RTC example available in LPCOpen ?
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc17xx-packages
Please also check the load capacitors used.
http://www.lpcware.com/content/faq/how-calculate-value-crystal-load-capacitors
NXP Technical Support
