how to flash LPC54102 board wihtout using lpcexpresso software at the customer end?
chethankumar
I am using board which contains LPC54102 chip. I want to update the firmware(newly created axf) of the board without using LPCExpresso IDE. What are the possible solutions available (ex:USB, UART or Wi-Fi)? Can it flashed using script?.
Please point us to the relevant document or any pre-written script.
ck
Labels (4)
lpcxpresso_supp
The user manual contains a chapter entitled 'the Flash API' which contains all the information you should need. Alternatively you could look at a tool such as FlashMagic Flash Magic - Welcome . Note you may need to extract the binary from the .axf image.
Yours,
LPCXpresso support
chethankumar
Is it possible to program the LPC54102 using LPCScript as suggested by below link
http://www.nxp.com/files/microcontrollers/doc/user_guide/LPCScrypt_User_Guide.pdf?fasp=1&WT_TYPE=Use...
However above link is for  LPC18/43 family. If it is possible to program the LPC54102 also can you provide the necessary script?.
Ck
