flash
flash
2,264件の閲覧回数
Anshu
Am using lpc54s018 evk board, trying to flash the code the following error is coming
3 返答(返信)
2,241件の閲覧回数
RaRo
Hello @Anshu,
Could you please try to flash another code, for example a LED Blinky example?
Also, could you please try to erase your launch before trying to flash or debug again?
Let us know if the issue still persists.
Best regards, Raul.
2,192件の閲覧回数
Anshu
Not solved yet. Problem still persisting.
2,166件の閲覧回数
RaRo
Hello @Anshu,
Could you please check the following information?
Let us know if this helps you.
Best regards, Raul.
