emWin memory check
emWin memory check
lpcware
Content originally posted in LPCWare by Cusko on Fri Feb 14 05:47:06 MST 2014
emWin does a short memory check at startup. The used memory allocated to emWin must be accessible 32-, 16- and 8-bit-wise. Code is hidden in GUI_Init(). Can I get this section of the code or how can I do it myself?
I have problem with external SRAM in combination with emWin, so I would like to test it with this code where it hangs.
