difference between FIODIR & IODIR
Content originally posted in LPCWare by moslem1368 on Sun Dec 02 02:59:49 MST 2012
What is difference between FIODIR &  IODIR Reg. in lpc21xx in Aplication?
Content originally posted in LPCWare by embd02161991 on Thu Aug 15 15:50:45 MST 2013
FIODIR refers to Fast Input/Output Direction control register and IODIR refers to Input/Output Direction control register. The purpose of FIO is basically application oriented. In case you have a external memory running at high frequencies and you want to communicate with it. Here, FIO's are better than IO's as they are faster.
SK
Content originally posted in LPCWare by omid.azadeh on Mon Apr 08 01:43:57 MST 2013
hi
FIODIR -> Fast Input/Output Direction
IODIR -> Normally Input/Output Direction
