complementary pwm with dead-time
12,083 次查看
mohit2904
I am trying to implement complementary PWM with dead-time for UPS application.
But as you can find in attached image dead time is working but not getting complementary PWM with this.
I am attaching Source code Please check and support me to solve this issue.
11,997 次查看
Hello @mohit2904
I tested your project on my side, find the issue,
Please change
/* SCTimer output 1 mask */
#define SCT0_OUTPUT_1 (1 << kSCTIMER_Out_1)
to
#define SCT0_OUTPUT_1 (0 << kSCTIMER_Out_1)
Then it can work well, below is my test result:
Alice
6 回复数
12,059 次查看
Hello @mohit2904
How about use MCUXpresso peripheral tool to config complementary PWM signals,
then generate code, refer to the code:
If still can't work, how about send your whole project to me , I help to check on my side.
Alice
12,012 次查看
mohit2904
Dear Alice,
            Thanks for your response please find the attachment for MCUXpresso peripheral tool settings and also find my complete project file and confirm what is issue exactly to getting complementary PWM in my case.
11,998 次查看
Hello @mohit2904
Please change
to
Alice
11,988 次查看
mohit2904
Thank you @ Alice_Yang !!!
For your support it is working now after doing changes suggested by you...
11,857 次查看
mohit2904
@Alice_Yang
Hello Alice,
       We are using SCT0 to generate complementary PWM that we have done but we need to adjust rise time around 2 nsec in our case so please help us how we can change it.
11,850 次查看
Hello @mohit2904
This thread is too long, about your new question, please create a new case with more detail description,
thanks.
Alice
