blhost on PC running Windows 11
kt
Hello
After updating to Windows 11 is blhost is unable to open USB HID Device.
Tested on LPC55S69-EVK.
Example blhost command:
LPC55S69 Boot-HID device is found/enumerated correct by PC:
Exact same command works fine on PC running Windows 10:
(Same PC hardware / USB connection - Windows 10 PC running as virtual machine).
Question: Why does blhost not connected to LPC55S69 bootloader when running on Windows 11 PC?
Regards Knud
Labels (2)
Tags (2)
Pavel_Hernandez
Hello, I confirm with your image you have the ISP mode, are you using LINUX?
Pavel
kt
Hello Pavel
Yes, I press and hold S1-ISP button while plugging USB cable into P9
(boot loader only activate if S1-ISP pressed during reset)
As already written, this problem only occurs when running on Windows 11 Pro system.
If I run a virtual Windows 10 Pro on same hardware (and same PC USB port) does blhost.exe run correct.
Please try to replicate problem on PC running Windows 11 Pro…
Knud
Pavel_Hernandez
Hello, I apologize I do not have at moment the board at home, my personal computer has win11, I have an OKDO, and I tested it but with VCOM.
The Win11 is communicating and is discarded, could you review if the jumpers are in default position? Could you please download the document and review the Table 1. Indicators, buttons, connectors and LEDs?
LPCXpresso55S69 Development Board | NXP Semiconductors
Pavel
kt
Hello Pavel
Thanks for your work on this issue, but this is a completely different test you made.
Let me summarize my findings:
  • blhost.exe works fine on my older Windows 10 PC, and on Virtual Windows 10 (via VMware Workstation 15 Player).
    I do therefor think that all settings, DIP switch, etc. is correct.
  • When running Windows 10 as virtual machine on Windows 11, did I use exact same USB port, cable, test procedure, etc.
  • On Windows 11 is nxpdevscan able to find LPC55S69 boot loader.
    This mean LPC55S69 bootloader is able to enumerate on USB
    i.e at minimum USB layer 1 and 2 is working correct.
  • Same problem when testing on LPC55S69-EVK and our application PCB using a LPC55S66 CPU.
From this I conclude: Problem is related to USB connection on Windows 11
The goal is to have a simple Windows problem that are able to firmware update via built in bootloader, which is fulfilled by blhost.exe
We do not like SPSDK because it also requires installation of Python interpreter, but it’s of cause OK for tracing the real problem with blhost.exe
Please make correct attempt to replicate problem: Windows 11 + USB connection.
Best regards Knud
Pavel_Hernandez
Hello, sorry but I could not offer a good solution if you are using the VMW this is beyond the scope, could you test it on native WIN11?
Pavel
kt
Hello Pavel
The problem is on native Windows 11.
I only use VMware to run older Windows 10 for further testing - and here it works fine
Running this test shows that cabling, USB hardware on PC, Switches / Jumpers on LPC55S69-EVK, command line parameters for blhost.exe, etc. is correct.
Knud
Pavel_Hernandez
Hello, let me try on my side this on win11 with the EVK tomorrow.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eblhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3EAfter%20updating%20to%20Windows%2011%20is%20blhost%20is%20unable%20to%20open%20USB%20HID%20Device.%3C%2FP%3E%3CP%3ETested%20on%20LPC55S69-EVK.%3C%2FP%3E%3CP%3EExample%20blhost%20command%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1713965459352.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1713965459352.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275568iCF769A681B2B3B61%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1713965459352.png%22%20alt%3D%22kt_0-1713965459352.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ELPC55S69%20Boot-HID%20device%20is%20found%2Fenumerated%20correct%20by%20PC%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_1-1713965481184.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_1-1713965481184.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275569iA67F5A34398BC14E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_1-1713965481184.png%22%20alt%3D%22kt_1-1713965481184.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EExact%20same%20command%20works%20fine%20on%20PC%20running%20Windows%2010%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_2-1713965668974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_2-1713965668974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275570i017119F65A9589C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_2-1713965668974.png%22%20alt%3D%22kt_2-1713965668974.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(Same%20PC%20hardware%20%2F%20USB%20connection%20-%20Windows%2010%20PC%20running%20as%20virtual%20machine).%3C%2FP%3E%3CP%3EQuestion%3A%20Why%20does%20blhost%20not%20connected%20to%20LPC55S69%20bootloader%20when%20running%20on%20Windows%2011%20PC%3F%3C%2FP%3E%3CP%3ERegards%20Knud%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F17173%22%20target%3D%22_blank%22%3E%40ErichStyger%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThanks%20for%20highlighting.%20We%20will%20try%20if%20this%20works%20for%20us.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOh%20Erich!%20I'm%20glad%20to%20get%20a%20response%20from%20you.%20%3CLI-EMOJI%20id%3D%22lia_nerd-face%22%20title%3D%22%3Anerd_face%3A%22%3E%3C%2FLI-EMOJI%3E%20Your%20mcuoneclipse%20articles%20have%20been%20very%20insightful%20and%20helpful%20over%20the%20last%20few%20years.%20Thank%20you%20very%20much%20for%20sharing%20your%20expertise.%3CBR%20%2F%3E%3CBR%20%2F%3ERegarding%20this%20new%20rblhost%20tool%2C%20I%20didn't%20have%20the%20faintest%20idea%20of%20its%20release.%20We%20will%20give%20it%20a%20try%20as%20soon%20as%20we%20can.%20Probably%20this%20week.%20I%20read%20that%20it%20is%20also%20possible%20to%20integrate%20it%20into%20a%20Python%20environment%2C%20which%20is%20good%20for%20us.%20Because%20we%20are%20using%20blhost%20in%20our%20automated%20test%20system%20based%20on%20Python%20and%20pytest.%3CBR%20%2F%3E%3CBR%20%2F%3EI'll%20let%20you%20and%20everyone%20know%20about%20how%20it%20goes.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20very%20much%20for%20your%20comment!%20It's%20a%20pity.%20This%20forum%20is%20an%20option%20and%20resource%2C%20but%20in%20general%2C%20it%20is%20unlikely%20that%20you%20will%20get%20a%20reliable%20answer%20or%20solution%20from%20NXP.%20Thanks!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWin11%20seems%20to%20have%20issues%20with%20USB%20devices%20in%20general.%20I%20just%20have%20switched%20to%20Win11%20and%20found%20out%20the%20hard%20way.%3C%2FP%3E%3CP%3EWhat%20I'm%20using%20now%20is%20rblhost%2C%20see%20my%20article%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F05%2Frblhost-exploring-rusts-role-in-embedded-development-tools%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F05%2Frblhost-exploring-rusts-role-in-embedded-development-tools%2F%3C%2FA%3E%3C%2FP%3E%3CP%3EIt%20is%20implemented%20in%20Rust%2C%20without%20dependencies%20to%20Python.%20So%20far%20it%20works%20fine%20for%20me%20under%20Windows%2011.%20So%20you%20might%20give%20it%20a%20try%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eyes%2C%20we%20have%20been%20following%20up%20for%20more%20than%20a%20year%20and%20no%20response%20or%20solution%20from%20NXP%20side.%20After%20developing%20the%20bootloader%2C%20it%20works%20in%20some%20pc's%20and%20does%20not%20work%20in%20others%2C%20and%20it%20is%20like%20the%20waste%20of%20effort.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20seems%20there%20is%20no%20fix%20or%20solution%20to%20this%20issue%2C%20isn't%20it%3F%3C%2FP%3E%3CP%3EWe%20are%20facing%20the%20same%20problem.%20We%20have%20blhost%20working%20on%20two%20different%20Windows%2011%20machines%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSTRONG%3EPC1%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EEdition%20Windows%2011%20Home%20Single%20Language%3CBR%20%2F%3EVersion%2024H2%3CBR%20%2F%3EInstalled%20on%20%E2%80%8E20%2F%E2%80%8E07%2F%E2%80%8E2025%3CBR%20%2F%3EOS%20build%2026100.6899%3CBR%20%2F%3EExperience%20Windows%20Feature%20Experience%20Pack%201000.26100.253.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EPC2%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EEdition%20Windows%2011%20Pro%3CBR%20%2F%3EVersion%2024H2%3CBR%20%2F%3EInstalled%20on%20%E2%80%8E2%2F%E2%80%8E13%2F%E2%80%8E2025%3CBR%20%2F%3EOS%20build%2026100.4946%3CBR%20%2F%3EExperience%20Windows%20Feature%20Experience%20Pack%201000.26100.197.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHowever%2C%20it%20is%20not%20working%20on%20the%20next%20machine%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3EPC3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EEdition%20Windows%2011%20Pro%3CBR%20%2F%3EVersion%2024H2%3CBR%20%2F%3EInstalled%20on%20%E2%80%8E24%2F%E2%80%8E4%2F%E2%80%8E2025%3CBR%20%2F%3EOS%20build%2026100.6899%3CBR%20%2F%3EExperience%20Windows%20Feature%20Experience%20Pack%26nbsp%3B1000.26100.253.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20summary%2C%20comparing%20PCs%202%20and%203%2C%20it%20seems%20that%20it%20is%20the%20bild%20version%20that%20breaks%20blhost.%20However%2C%20comparing%20PCs%201%20and%203%2C%20it%20seems%20to%20be%20the%20OS%20version%20(Home%20vs%20Pro)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1933342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1933342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EWe%20are%20also%20facing%20the%20same%20issue.%20I%20have%20also%20raised%20it%20few%20weeks%20back.%20When%20I%20testes%20it%20around%20March%20of%20this%20year%20it%20was%20working%20fine.%20I%20also%20had%20windows%2011%20at%20that%20time.%20But%20now%20it%20is%20not%20working.%20Now%20the%20Windows%2011%20version%20is%2023H2.%20Can%20you%20please%20provide%20us%20some%20solution.%3C%2FP%3E%3CP%3EThanks%20for%20your%20help%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%26nbsp%3Bit%20does%20NOT%20work%20on%20Windows%2011%26nbsp%3B%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E23H2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20are%20also%20seeing%20this%20issue.%20It%20seems%20to%20work%20on%20Windows%2011%20version%2021H2%20but%20it%20is%20NOT%20working%20on%20a%20later%20version%20on%20a%20different%20computer.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20any%20resolution%20or%20workaround%20to%20this%20problem%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1920062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1920062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20am%20facing%20the%20similar%20issue.%20I%20am%20using%20the%20MCUBootUtility%20to%20program%20the%20board%20using%20OTA%20bootloader.%20The%20bootloader%20was%20working%20fine%20previously.%20But%20now%20when%20I%20try%20to%20connect%20using%20the%20BootUtility%20tool%20it%20is%20giving%20the%20following%20error%20'%20Failed%20to%20ping%20SBL%20ISP%20component%2C%20Please%20double%20check%20it%20is%20SBL%20target!'.%3C%2FP%3E%3CP%3EI%20can%20see%20the%20USB%20is%20enumerated%20as%20HID%20but%20not%20able%20to%20connect%20to%20SBL.%20Your%20quick%20help%20on%20this%20is%20highly%20appreciated.%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1913684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EUnfortunately%20not%20solved%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3EPavel%20Hernandez%20(NXP%20Support)%20does%20no%20recommend%20to%20use%20blhost%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3EPavel%20says%20that%20SPSDK%20work%20fine%20on%20his%20Win%2011%20setup%2C%20but%20it%20does%20not%20work%20on%20my%20Win%2011%20PC.%3CBR%20%2F%3ESPSDK%20also%20require%20installation%20of%20Phyton%20interpreter%2C%20which%20is%20to%20complicate%20for%20use%20in%20our%20product%20Service%20center.%3C%2FP%3E%3CP%3EI%20am%20still%20very%20interested%20in%20using%20blhost%20on%20Win%2011%20-%20maybe%20you%20are%20able%20to%20find%20solutiuon%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1913491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIm%20seeing%20the%20exact%20same%20thing.%26nbsp%3B%20blhost%20usb%20hid%20works%20on%20Win%2010%20not%20Win%2011.%3C%2FP%3E%3CP%3EHas%20this%20issue%20been%20resolved%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20did%20the%20test%2C%20and%20this%20is%20my%20result.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277070iA28B142F22D3077A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714753540897.png%22%20alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277071i6F3F9FA24E04F8B9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_1-1714753551052.png%22%20alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20my%20apologize%20I%20will%20test%20it%20at%20these%20days.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20did%20your%20test%20on%20Windows%2011%20go%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20let%20me%20try%20on%20my%20side%20this%20on%20win11%20with%20the%20EVK%20tomorrow.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pavel%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20problem%20is%20on%20native%20Windows%2011.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20only%20use%20VMware%20to%20run%20older%20Windows%2010%20for%20further%20testing%20-%20and%20here%20it%20works%20fine%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3ERunning%20this%20test%20shows%20that%20cabling%2C%20USB%20hardware%20on%20PC%2C%20Switches%20%2F%20Jumpers%20on%20LPC55S69-EVK%2C%20command%20line%20parameters%20for%20blhost.exe%2C%20etc.%20is%20correct.%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EKnud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20sorry%20but%20I%20could%20not%20offer%20a%20good%20solution%20if%20you%20are%20using%20the%20VMW%20this%20is%20beyond%20the%20scope%2C%20could%20you%20test%20it%20on%20native%20WIN11%3F%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pavel%3C%2FP%3E%3CP%3EThanks%20for%20your%20work%20on%20this%20issue%2C%20but%20this%20is%20a%20completely%20different%20test%20you%20made.%3C%2FP%3E%3CP%3ELet%20me%20summarize%20my%20findings%3A%3C%2FP%3E%3CUL%3E%3CLI%3Eblhost.exe%20works%20fine%20on%20my%20older%20Windows%2010%20PC%2C%20and%20on%20Virtual%20Windows%2010%20(via%20VMware%20Workstation%2015%20Player).%3CBR%20%2F%3EI%20do%20therefor%20think%20that%20all%20settings%2C%20DIP%20switch%2C%20etc.%20is%20correct.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EWhen%20running%20Windows%2010%20as%20virtual%20machine%20on%20Windows%2011%2C%20did%20I%20use%20exact%20same%20USB%20port%2C%20cable%2C%20test%20procedure%2C%20etc.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EOn%20Windows%2011%20is%20nxpdevscan%20able%20to%20find%20LPC55S69%20boot%20loader.%3CBR%20%2F%3EThis%20mean%20LPC55S69%20bootloader%20is%20able%20to%20enumerate%20on%20USB%3CBR%20%2F%3Ei.e%20at%20minimum%20USB%20layer%201%20and%202%20is%20working%20correct.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3ESame%20problem%20when%20testing%20on%20LPC55S69-EVK%20and%20our%20application%20PCB%20using%20a%20LPC55S66%20CPU.%3C%2FLI%3E%3C%2FUL%3E%3CP%3EFrom%20this%20I%20conclude%3A%20Problem%20is%20related%20to%20USB%20connection%20on%20Windows%2011%3C%2FP%3E%3CP%3EThe%20goal%20is%20to%20have%20a%20simple%20Windows%20problem%20that%20are%20able%20to%20firmware%20update%20via%20built%20in%20bootloader%2C%20which%20is%20fulfilled%20by%20blhost.exe%3C%2FP%3E%3CP%3EWe%20do%20not%20like%20SPSDK%20because%20it%20also%20requires%20installation%20of%20Python%20interpreter%2C%20but%20it%E2%80%99s%20of%20cause%20OK%20for%20tracing%20the%20real%20problem%20with%20blhost.exe%3C%2FP%3E%3CP%3EPlease%20make%20correct%20attempt%20to%20replicate%20problem%3A%20Windows%2011%20%2B%20USB%20connection.%3C%2FP%3E%3CP%3EBest%20regards%20Knud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20apologize%20I%20do%20not%20have%20at%20moment%20the%20board%20at%20home%2C%20my%20personal%20computer%20has%20win11%2C%20I%20have%20an%20OKDO%2C%20and%20I%20tested%20it%20but%20with%20VCOM.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20style%3D%22width%3A%20313px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F276239i2AEDC6DF6CB729EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714168177523.png%22%20alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20Win11%20is%20communicating%20and%20is%20discarded%2C%20could%20you%20review%20if%20the%20jumpers%20are%20in%20default%20position%3F%20Could%20you%20please%20download%20the%20document%20and%20review%20the%20Table%201.%20Indicators%2C%20buttons%2C%20connectors%20and%20LEDs%3F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Flpcxpresso-boards%2Flpcxpresso55s69-development-board%3ALPC55S69-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPCXpresso55S69%20Development%20Board%20%7C%20NXP%20Semiconductors%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F276241iA2C1BF1B4320C1A9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_1-1714168309951.png%22%20alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pavel%3C%2FP%3E%3CP%3EYes%2C%20I%20press%20and%20hold%20S1-ISP%20button%20while%20plugging%20USB%20cable%20into%20P9%3C%2FP%3E%3CP%3E(boot%20loader%20only%20activate%20if%20S1-ISP%20pressed%20during%20reset)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAs%20already%20written%2C%20this%20problem%20only%20occurs%20when%20running%20on%20Windows%2011%20Pro%20system.%3C%2FP%3E%3CP%3EIf%20I%20run%20a%20virtual%20Windows%2010%20Pro%20on%20same%20hardware%20(and%20same%20PC%20USB%20port)%20does%20blhost.exe%20run%20correct.%3C%2FP%3E%3CP%3EPlease%20try%20to%20replicate%20problem%20on%20PC%20running%20Windows%2011%20Pro%E2%80%A6%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EKnud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20confirm%20with%20your%20image%20you%20have%20the%20ISP%20mode%2C%20are%20you%20using%20LINUX%3F%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20did%20you%20put%20the%20Board%20in%20ISP%20mode%3F%3C%2FP%3E%0A%3CP%3EI%20test%20it%20on%20my%20side%20with%20the%20LPC55s69%20with%20the%20HS-USB%20(P9)%20and%20the%20ISP%20button%20(S1).%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275969i292B4ECF3569B09C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714079479432.png%22%20alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pavel%3C%2FP%3E%3CP%3EAgain%2C%20thanks%20for%20your%20reply%20%E2%80%93%20very%20appreciated.%3C%2FP%3E%3CP%3EHave%20made%202%20new%20test%20with%20correct%20PID%20parameter%3A%26nbsp%3B%20No%20change%20%2F%20same%20problem%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1714068985565.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1714068985565.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275936iD2E74C78E428B63C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1714068985565.png%22%20alt%3D%22kt_0-1714068985565.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_1-1714068998365.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_1-1714068998365.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275937i2DE1DB9E37C11AD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_1-1714068998365.png%22%20alt%3D%22kt_1-1714068998365.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EKnud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20tested%20it%20on%20my%20side%20and%20then%20had%20the%20same%20issue%2C%20but%20then%20I%20saw%20you%20miss%20a%200%20on%20the%20PID%20section%2C%20try%20with%200x0020.%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20the%20issue%20is%20still%20there.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pavel%3C%2FP%3E%3CP%3EThanks%20a%20lot%20for%20fast%20response%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3EHave%20installed%20SPSDK%2C%20but%20have%20more%20or%20less%20same%20problem%20%E2%80%93%20see%20screen%20dump%20below%3A%3C%2FP%3E%3CUL%3E%3CLI%3Enxpdevscan%20command%20is%20able%20to%20find%20LPC55S66%20device.%3C%2FLI%3E%3CLI%3Eblhost%20command%20is%20not%20able%20open%20communication%20(here%20for%20a%20simple%20reset%20command)%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1714030318170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1714030318170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275795iA8CD409E0D7846CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1714030318170.png%22%20alt%3D%22kt_0-1714030318170.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBut%2C%20I%20am%20looking%20for%20a%20%E2%80%98simpler%E2%80%99%20tool%20than%20installing%20Python%20interpreter%20%2B%20SPSDK%20package%20%E2%80%93%20here%20blhost.exe%20is%20perfect.%3C%2FP%3E%3CP%3ENeed%20the%20tool%20for%202%20purposes%3A%3C%2FP%3E%3CUL%3E%3CLI%3EIn%20production%20line%20for%20flash%20programming%2C%20read%20out%20of%20UUID%2C%20etc.%3C%2FLI%3E%3CLI%3EFor%20firmware%20update%20at%20consumer%20customer%20%2F%20product%20repair%20center.%3CBR%20%2F%3EFor%20this%2C%20I%20need%20simpler%20tool%20than%20SPSDK%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EQuestions%3A%3C%2FP%3E%3CUL%3E%3CLI%3EIs%20my%20problem%20related%20to%20Windows%2011%20or%20do%20I%20have%20to%20look%20for%20other%20issues%3F%3CBR%20%2F%3EIf%20yes%3A%20When%20can%20I%20expect%20an%20update%20of%20blhost.exe%20that%20run%20on%20Windows%2011%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EDoes%20other%20simple%20program%20for%20firmware%20updating%20LPC55xxx%20CPU%20via%20USB%20exists%3F%3CBR%20%2F%3EIf%20yes%3A%20Any%20suggestion%20to%20fix%20my%20problem%E2%80%A6%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3EPS.%3A%20Same%20problem%20on%20LPC55S69-EVK%20and%20LPC55S66%20used%20in%20our%20application%3C%2FP%3E%3CP%3ERegards%20Knud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20my%20name%20is%20Pavel%2C%20and%20I%20will%20be%20supporting%20your%20case%2C%20I%20suggest%20using%20the%20SPSDK%20this%20is%20the%20newest%20tool%20that%20has%20integrated%20a%20bunch%20of%20tools%20into%20one%20site.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fspsdk.readthedocs.io%2Fen%2Flatest%2Fusage%2Finstallation.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EInstallation%20Guide%20%E2%80%94%20SPSDK%20documentation%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
