blhost on PC running Windows 11
8,570 次查看
kt
Hello
After updating to Windows 11 is blhost is unable to open USB HID Device.
Tested on LPC55S69-EVK.
Example blhost command:
LPC55S69 Boot-HID device is found/enumerated correct by PC:
Exact same command works fine on PC running Windows 10:
(Same PC hardware / USB connection - Windows 10 PC running as virtual machine).
Question: Why does blhost not connected to LPC55S69 bootloader when running on Windows 11 PC?
Regards Knud
标签 (2)
标记 (2)
27 回复数
7,617 次查看
Pavel_Hernandez
Hello, I confirm with your image you have the ISP mode, are you using LINUX?
Pavel
7,553 次查看
kt
Hello Pavel
Yes, I press and hold S1-ISP button while plugging USB cable into P9
(boot loader only activate if S1-ISP pressed during reset)
As already written, this problem only occurs when running on Windows 11 Pro system.
If I run a virtual Windows 10 Pro on same hardware (and same PC USB port) does blhost.exe run correct.
Please try to replicate problem on PC running Windows 11 Pro…
Knud
7,534 次查看
Pavel_Hernandez
Hello, I apologize I do not have at moment the board at home, my personal computer has win11, I have an OKDO, and I tested it but with VCOM.
The Win11 is communicating and is discarded, could you review if the jumpers are in default position? Could you please download the document and review the Table 1. Indicators, buttons, connectors and LEDs?
LPCXpresso55S69 Development Board | NXP Semiconductors
Pavel
7,469 次查看
kt
Hello Pavel
Thanks for your work on this issue, but this is a completely different test you made.
Let me summarize my findings:
  • blhost.exe works fine on my older Windows 10 PC, and on Virtual Windows 10 (via VMware Workstation 15 Player).
    I do therefor think that all settings, DIP switch, etc. is correct.
  • When running Windows 10 as virtual machine on Windows 11, did I use exact same USB port, cable, test procedure, etc.
  • On Windows 11 is nxpdevscan able to find LPC55S69 boot loader.
    This mean LPC55S69 bootloader is able to enumerate on USB
    i.e at minimum USB layer 1 and 2 is working correct.
  • Same problem when testing on LPC55S69-EVK and our application PCB using a LPC55S66 CPU.
From this I conclude: Problem is related to USB connection on Windows 11
The goal is to have a simple Windows problem that are able to firmware update via built in bootloader, which is fulfilled by blhost.exe
We do not like SPSDK because it also requires installation of Python interpreter, but it’s of cause OK for tracing the real problem with blhost.exe
Please make correct attempt to replicate problem: Windows 11 + USB connection.
Best regards Knud
7,368 次查看
Pavel_Hernandez
Hello, sorry but I could not offer a good solution if you are using the VMW this is beyond the scope, could you test it on native WIN11?
Pavel
7,309 次查看
kt
Hello Pavel
The problem is on native Windows 11.
I only use VMware to run older Windows 10 for further testing - and here it works fine
Running this test shows that cabling, USB hardware on PC, Switches / Jumpers on LPC55S69-EVK, command line parameters for blhost.exe, etc. is correct.
Knud
1,331 次查看
Pavel_Hernandez
Hello, let me try on my side this on win11 with the EVK tomorrow.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E8%BF%90%E8%A1%8C%20Windows%2011%20%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E8%BF%90%E8%A1%8C%20blhost%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E5%88%B0%20Windows%2011%20%E5%90%8E%EF%BC%8Cblhost%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20USB%20HID%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%9C%A8%20LPC55S69-EVK%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3Eblhost%20%E5%91%BD%E4%BB%A4%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1713965459352.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1713965459352.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275568iCF769A681B2B3B61%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1713965459352.png%22%20alt%3D%22kt_0-1713965459352.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%B5%E8%84%91%E5%8F%91%E7%8E%B0%2F%E6%9E%9A%E4%B8%BE%E4%BA%86%20LPC55S69%20%E5%90%AF%E5%8A%A8-HID%20%E8%AE%BE%E5%A4%87%E6%AD%A3%E7%A1%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_1-1713965481184.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_1-1713965481184.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275569iA67F5A34398BC14E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_1-1713965481184.png%22%20alt%3D%22kt_1-1713965481184.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%91%BD%E4%BB%A4%E5%9C%A8%E8%BF%90%E8%A1%8C%20Windows%2010%20%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_2-1713965668974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_2-1713965668974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275570i017119F65A9589C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_2-1713965668974.png%22%20alt%3D%22kt_2-1713965668974.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(%E7%9B%B8%E5%90%8C%E7%9A%84%E7%94%B5%E8%84%91%E7%A1%AC%E4%BB%B6%2FUSB%20%E8%BF%9E%E6%8E%A5%20-%20%E4%BD%9C%E4%B8%BA%E8%99%9A%E6%8B%9F%E6%9C%BA%E8%BF%90%E8%A1%8C%E7%9A%84%20Windows%2010%20%E7%94%B5%E8%84%91%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%9C%A8%20Windows%2011%20%E7%94%B5%E8%84%91%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%20blhost%20%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPC55S69%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%20Knud%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1853499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F17173%22%20target%3D%22_blank%22%3E%40ErichStyger%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BC%BA%E8%B0%83%E3%80%82%E6%88%91%E4%BB%AC%E4%BC%9A%E8%AF%95%E8%AF%95%E8%BF%99%E6%98%AF%E5%90%A6%E9%80%82%E5%90%88%E6%88%91%E4%BB%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%93%A6%EF%BC%8C%E5%9F%83%E9%87%8C%E5%B8%8C%E5%BE%88%E9%AB%98%E5%85%B4%E5%BE%97%E5%88%B0%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%20%3CLI-EMOJI%20id%3D%22lia_nerd-face%22%20title%3D%22%3Anerd_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%9C%A8%E8%BF%87%E5%8E%BB%E7%9A%84%E5%87%A0%E5%B9%B4%E9%87%8C%EF%BC%8C%E6%82%A8%E5%9C%A8%20mcuoneclipse%20%E4%B8%8A%E5%8F%91%E8%A1%A8%E7%9A%84%E6%96%87%E7%AB%A0%E5%BE%88%E6%9C%89%E8%A7%81%E5%9C%B0%EF%BC%8C%E4%B9%9F%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E5%88%86%E4%BA%AB%E4%BD%A0%E7%9A%84%E4%B8%93%E4%B8%9A%E7%9F%A5%E8%AF%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%E6%96%B0%E7%9A%84%20rblhost%20%E5%B7%A5%E5%85%B7%EF%BC%8C%E6%88%91%E5%AF%B9%E5%AE%83%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%80%E6%97%A0%E6%89%80%E7%9F%A5%E3%80%82%E6%88%91%E4%BB%AC%E4%BC%9A%E5%B0%BD%E5%BF%AB%E8%AF%95%E4%B8%80%E8%AF%95%E3%80%82%E5%8F%AF%E8%83%BD%E6%98%AF%E8%BF%99%E5%91%A8%E3%80%82%E6%88%91%E8%AF%BB%E5%88%B0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E9%9B%86%E6%88%90%E5%88%B0%20Python%20%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%8C%E8%BF%99%E5%AF%B9%E6%88%91%E4%BB%AC%E6%9C%89%E5%A5%BD%E5%A4%84%E3%80%82%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E5%9C%A8%E5%9F%BA%E4%BA%8E%20Python%20%E5%92%8C%20pytest%20%E7%9A%84%E8%87%AA%E5%8A%A8%E6%B5%8B%E8%AF%95%E7%B3%BB%E7%BB%9F%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%20blhost%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BC%9A%E8%AE%A9%E4%BD%A0%E5%92%8C%E5%A4%A7%E5%AE%B6%E7%9F%A5%E9%81%93%E8%BF%9B%E5%B1%95%E5%A6%82%E4%BD%95%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%AF%84%E8%AE%BA%EF%BC%81%E7%9C%9F%E9%81%97%E6%86%BE%E3%80%82%E6%9C%AC%E8%AE%BA%E5%9D%9B%E6%98%AF%E4%B8%80%E7%A7%8D%E9%80%89%E6%8B%A9%E5%92%8C%E8%B5%84%E6%BA%90%EF%BC%8C%E4%BD%86%E4%B8%80%E8%88%AC%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%82%A8%E4%B8%8D%E5%A4%AA%E5%8F%AF%E8%83%BD%E4%BB%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E8%8E%B7%E5%BE%97%E5%8F%AF%E9%9D%A0%E7%9A%84%E7%AD%94%E6%A1%88%E6%88%96%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%80%BB%E7%9A%84%E6%9D%A5%E8%AF%B4%EF%BC%8CWin11%E4%BC%BC%E4%B9%8E%E5%9C%A8%E4%BD%BF%E7%94%A8USB%E8%AE%BE%E5%A4%87%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%88%9A%E6%8D%A2%E4%B8%8A%20Win11%EF%BC%8C%E5%B0%B1%E5%8F%91%E7%8E%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20rblhost%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E7%9A%84%E6%96%87%E7%AB%A0%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F05%2Frblhost-exploring-rusts-role-in-embedded-development-tools%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F05%2Frblhost-exploring-rusts-role-in-embedded-development-tools%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E6%98%AF%E7%94%A8%20Rust%20%E5%AE%9E%E7%8E%B0%E7%9A%84%EF%BC%8C%E4%B8%8D%E4%BE%9D%E8%B5%96%20Python%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E5%AE%83%E5%9C%A8%20Windows%2011%20%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E9%82%A3%E4%B9%88%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E8%B7%9F%E8%BF%9B%E4%BA%86%E4%B8%80%E5%B9%B4%E5%A4%9A%EF%BC%8C%E4%BD%86%E6%81%A9%E6%99%BA%E6%B5%A6%E6%96%B9%E9%9D%A2%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%9B%9E%E5%BA%94%E6%88%96%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E5%9C%A8%E5%BC%80%E5%8F%91%E4%BA%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%AE%83%E5%9C%A8%E6%9F%90%E4%BA%9B%E7%94%B5%E8%84%91%E4%B8%8A%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%80%8C%E5%9C%A8%E5%8F%A6%E4%B8%80%E4%BA%9B%E7%94%B5%E8%84%91%E4%B8%8A%E5%8D%B4%E4%B8%8D%E8%83%BD%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%BF%99%E6%97%A0%E5%BC%82%E4%BA%8E%E7%99%BD%E8%B4%B9%E5%8A%9B%E6%B0%94%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%EF%BC%8C%E4%B8%8D%E6%98%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E9%9D%A2%E4%B8%B4%E7%9D%80%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E5%9C%A8%E4%B8%A4%E5%8F%B0%E4%B8%8D%E5%90%8C%E7%9A%84%20Windows%2011%20%E6%9C%BA%E5%99%A8%E4%B8%8A%E8%BF%90%E8%A1%8C%20blhost%EF%BC%9A%3C%2FP%3E%3CP%3E%20%3CSTRONG%3EPC1%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%20Windows%2011%20%E5%AE%B6%E5%BA%AD%E7%89%88%E5%8D%95%E8%AF%AD%E8%A8%80%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%2024H2%20%3CBR%20%2F%3E%20%E5%AE%89%E8%A3%85%E5%9C%A8%E2%80%8E20%2F%E2%80%8E07%2F%E2%80%8E2025%20%3CBR%20%2F%3E%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%88%E6%9C%AC%2026100.6899%20%3CBR%20%2F%3E%E4%BD%93%E9%AA%8C%20Windows%20%E5%8A%9F%E8%83%BD%E4%BD%93%E9%AA%8C%E5%8C%85%201000.26100.253.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EPC2%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%20Windows%2011%20%E4%B8%93%E4%B8%9A%3CBR%20%2F%3E%E7%89%88%2024H2%20%3CBR%20%2F%3E%20%E5%AE%89%E8%A3%85%E5%9C%A8%E2%80%8E2%2F%E2%80%8E13%2F%E2%80%8E2025%20%3CBR%20%2F%3E%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%88%E6%9C%AC%2026100.4946%20%3CBR%20%2F%3E%E4%BD%93%E9%AA%8C%20Windows%20%E5%8A%9F%E8%83%BD%E4%BD%93%E9%AA%8C%E5%8C%85%201000.26100.197.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%83%E5%9C%A8%E4%B8%8B%E4%B8%80%E5%8F%B0%E6%9C%BA%E5%99%A8%E4%B8%8A%E5%8D%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3EPC3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%20Windows%2011%20%E4%B8%93%E4%B8%9A%3CBR%20%2F%3E%E7%89%88%2024H2%20%3CBR%20%2F%3E%20%E5%AE%89%E8%A3%85%E5%9C%A8%E2%80%8E24%2F%E2%80%8E4%2F%E2%80%8E2025%20%3CBR%20%2F%3E%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%88%E6%9C%AC%2026100.6899%20%3CBR%20%2F%3E%E4%BD%93%E9%AA%8C%20Windows%20%E5%8A%9F%E8%83%BD%E4%BD%93%E9%AA%8C%E5%8C%85%201000.26100.253.0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%AF%94%E8%BE%83%20PC%202%20%E5%92%8C%20PC%203%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%98%AF%20bild%20%E7%89%88%E6%9C%AC%E7%A0%B4%E5%9D%8F%E4%BA%86%20blhost%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%AF%94%E8%BE%83%20PC%201%20%E5%92%8C%20PC%203%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%98%AF%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%88%E6%9C%AC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%88%E5%AE%B6%E5%BA%AD%E7%89%88%E4%B8%8E%E4%B8%93%E4%B8%9A%E7%89%88%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1933342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1933342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E9%9D%A2%E4%B8%B4%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%87%A0%E5%91%A8%E5%89%8D%EF%BC%8C%E6%88%91%E4%B9%9F%E6%8F%90%E5%87%BA%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%9C%A8%E4%BB%8A%E5%B9%B4%203%20%E6%9C%88%E5%B7%A6%E5%8F%B3%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E5%BD%93%E6%97%B6%E6%88%91%E8%BF%98%E7%94%A8%E7%9A%84%E6%98%AF%20windows%2011%E3%80%82%E4%BD%86%E7%8E%B0%E5%9C%A8%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86%E3%80%82%E7%8E%B0%E5%9C%A8%20Windows%2011%20%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%2023H2%E3%80%82%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%E5%AE%83%E5%9C%A8%20Windows%2011%20%E4%B8%8A%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%20%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E23H2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E7%9C%8B%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%9C%A8%20Windows%2011%20%E7%89%88%E6%9C%AC%2021H2%20%E4%B8%8A%E4%BC%BC%E4%B9%8E%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E7%9A%84%E5%90%8E%E7%BB%AD%E7%89%88%E6%9C%AC%E4%B8%8A%E5%8D%B4%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E6%88%96%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1920062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1920062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20MCUBootUtility%20%E4%BD%BF%E7%94%A8%20OTA%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B9%8B%E5%89%8D%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E4%BD%86%E6%98%AF%E7%8E%B0%E5%9C%A8%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20BootUtility%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%E6%97%B6%EF%BC%8C%E5%AE%83%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9C%E6%97%A0%E6%B3%95ping%20SBL%20ISP%20%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%8C%E8%AF%B7%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E5%AE%83%E6%98%AF%20SBL%20%E7%9B%AE%E6%A0%87%EF%BC%81%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20USB%20%E8%A2%AB%E6%9E%9A%E4%B8%BE%E4%B8%BA%20HID%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%20SBL%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1913684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3EPavel%20Hernandez%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E9%83%A8%E9%97%A8%EF%BC%89%E4%B8%8D%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20blhost%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3EPavel%20%E8%AF%B4%EF%BC%8CSPSDK%20%E5%9C%A8%E4%BB%96%E7%9A%84%20Win%2011%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%88%91%E7%9A%84%20Win%2011%20%E7%94%B5%E8%84%91%E4%B8%8A%E5%8D%B4%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3ESPSDK%20%E8%BF%98%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20Phyton%20%E8%A7%A3%E9%87%8A%E5%99%A8%EF%BC%8C%E8%BF%99%E5%AF%B9%E4%BA%8E%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E6%9C%8D%E5%8A%A1%E4%B8%AD%E5%BF%83%E6%9D%A5%E8%AF%B4%E8%BF%87%E4%BA%8E%E5%A4%8D%E6%9D%82%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8D%E7%84%B6%E5%AF%B9%E5%9C%A8%20Win%2011%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20blhost%20%E9%9D%9E%E5%B8%B8%E6%84%9F%E5%85%B4%E8%B6%A3%20-%20%E4%B9%9F%E8%AE%B8%E6%82%A8%E8%83%BD%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1913491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E7%9C%8B%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%20blhost%20USB%20hid%20%E5%8F%AF%E5%9C%A8%20Win%2010%20%E8%80%8C%E9%9D%9E%20Win%2011%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%81%9A%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277070iA28B142F22D3077A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714753540897.png%22%20alt%3D%22Pavel_Hernandez_0-1714753540897.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277071i6F3F9FA24E04F8B9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_1-1714753551052.png%22%20alt%3D%22Pavel_Hernandez_1-1714753551052.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%BC%9A%E5%9C%A8%E8%BF%99%E5%87%A0%E5%A4%A9%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%9C%A8%20Windows%2011%20%E4%B8%8A%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E8%AE%A9%E6%88%91%E6%98%8E%E5%A4%A9%E5%9C%A8%20Win11%20%E4%B8%8A%E7%94%A8%20EVK%20%E8%AF%95%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E6%9C%AC%E5%9C%B0%20Windows%2011%20%E4%B8%8A%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E4%BD%BF%E7%94%A8%20VMware%20%E8%BF%90%E8%A1%8C%E6%97%A7%E7%89%88%20Windows%2010%20%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%9C%A8%E8%BF%99%E9%87%8C%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%E8%BF%90%E8%A1%8C%E8%AF%A5%E6%B5%8B%E8%AF%95%E8%A1%A8%E6%98%8E%EF%BC%8C%E5%B8%83%E7%BA%BF%E3%80%81PC%20%E4%B8%8A%E7%9A%84%20USB%20%E7%A1%AC%E4%BB%B6%E3%80%81LPC55S69-EVK%20%E4%B8%8A%E7%9A%84%E5%BC%80%E5%85%B3%2F%E8%B7%B3%E7%BA%BF%E3%80%81blhost.exe%20%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%81%E7%AD%89%E7%AD%89%E9%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%85%8B%E5%8A%AA%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20VMW%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%E5%BE%88%E5%A5%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%BF%99%E8%B6%85%E5%87%BA%E4%BA%86%E6%88%91%E7%9A%84%E8%83%BD%E5%8A%9B%E8%8C%83%E5%9B%B4%EF%BC%8C%E6%82%A8%E8%83%BD%E5%9C%A8%E6%9C%AC%E5%9C%B0%20WIN11%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%89%80%E5%81%9A%E7%9A%84%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E6%82%A8%E5%81%9A%E7%9A%84%E4%B8%80%E4%B8%AA%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%AE%A9%E6%88%91%E6%80%BB%E7%BB%93%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%E5%8F%91%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Eblhost.exe%20%E5%9C%A8%E6%88%91%E7%9A%84%E6%97%A7%E7%89%88%20Windows%2010%20%E7%94%B5%E8%84%91%E5%92%8C%E8%99%9A%E6%8B%9F%20Windows%2010%EF%BC%88%E9%80%9A%E8%BF%87%20VMware%20Workstation%2015%20Player%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%89%80%E6%9C%89%E8%AE%BE%E7%BD%AE%E3%80%81DIP%20%E5%BC%80%E5%85%B3%E7%AD%89%E9%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20Windows%2011%20%E4%B8%8A%E4%BB%A5%E8%99%9A%E6%8B%9F%E6%9C%BA%E5%BD%A2%E5%BC%8F%E8%BF%90%E8%A1%8C%20Windows%2010%20%E6%97%B6%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%81%E7%94%B5%E7%BC%86%E5%92%8C%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F%E7%AD%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20Windows%2011%20%E4%B8%8A%EF%BC%8Cnxpdevscan%20%E8%83%BD%E5%A4%9F%E6%89%BE%E5%88%B0%20LPC55S69%20%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20LPC55S69%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E8%83%BD%E5%A4%9F%E5%9C%A8%20USB%20%E4%B8%8A%E6%9E%9A%E4%B8%BE%EF%BC%8C%3CBR%20%2F%3E%E5%8D%B3%E8%87%B3%E5%B0%91%20USB%20%E7%AC%AC%201%20%E5%B1%82%E5%92%8C%E7%AC%AC%202%20%E5%B1%82%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20LPC55S69-EVK%20%E5%92%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20LPC55S66%20CPU%20%E7%9A%84%E5%BA%94%E7%94%A8%20PCB%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E6%97%B6%E4%B9%9F%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%94%B1%E6%AD%A4%E6%88%91%E5%BE%97%E5%87%BA%E7%BB%93%E8%AE%BA%E9%97%AE%E9%A2%98%E4%B8%8E%20Windows%2011%20%E4%B8%8A%E7%9A%84%20USB%20%E8%BF%9E%E6%8E%A5%E6%9C%89%E5%85%B3%3C%2FP%3E%3CP%3E%E7%9B%AE%E6%A0%87%E6%98%AF%E8%A7%A3%E5%86%B3%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20Windows%20%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%A5%E9%97%AE%E9%A2%98%E8%83%BD%E5%A4%9F%E9%80%9A%E8%BF%87%E5%86%85%E7%BD%AE%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%EF%BC%8C%E7%94%B1%20blhost.exe%20%E8%A7%A3%E5%86%B3%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%B8%8D%E5%96%9C%E6%AC%A2%20SPSDK%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E8%BF%98%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20Python%20%E8%A7%A3%E9%87%8A%E5%99%A8%EF%BC%8C%E4%BD%86%E5%AE%83%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8E%E8%BF%BD%E8%B8%AA%20blhost.exe%20%E7%9A%84%E7%9C%9F%E6%AD%A3%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E6%AD%A3%E7%A1%AE%E5%A4%8D%E5%88%B6%E9%97%AE%E9%A2%98%EF%BC%9AWindows%2011%20%2B%20USB%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%E5%85%8B%E5%8A%AA%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E6%88%91%E7%8E%B0%E5%9C%A8%E5%AE%B6%E9%87%8C%E6%B2%A1%E6%9C%89%E6%9D%BF%EF%BC%8C%E6%88%91%E7%9A%84%E4%B8%AA%E4%BA%BA%E7%94%B5%E8%84%91%E6%9C%89%20win11%EF%BC%8C%E6%88%91%E6%9C%89%20OKDO%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%E4%BA%86%20VCOM%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20style%3D%22width%3A%20313px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F276239i2AEDC6DF6CB729EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714168177523.png%22%20alt%3D%22Pavel_Hernandez_0-1714168177523.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWin11%20%E6%AD%A3%E5%9C%A8%E9%80%9A%E4%BF%A1%E5%B9%B6%E8%A2%AB%E4%B8%A2%E5%BC%83%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%B7%B3%E7%BA%BF%E6%98%AF%E5%90%A6%E5%A4%84%E4%BA%8E%E9%BB%98%E8%AE%A4%E4%BD%8D%E7%BD%AE%EF%BC%9F%E8%AF%B7%E4%B8%8B%E8%BD%BD%E8%AF%A5%E6%96%87%E4%BB%B6%E5%B9%B6%E6%9F%A5%E7%9C%8B%E8%A1%A8%201%E3%80%82%E6%8C%87%E7%A4%BA%E7%81%AF%E3%80%81%E6%8C%89%E9%92%AE%E3%80%81%E8%BF%9E%E6%8E%A5%E5%99%A8%E5%92%8C%20LED%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Flpcxpresso-boards%2Flpcxpresso55s69-development-board%3ALPC55S69-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ElpcXpresso55s69%20%E5%BC%80%E5%8F%91%E6%9D%BF%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F276241iA2C1BF1B4320C1A9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_1-1714168309951.png%22%20alt%3D%22Pavel_Hernandez_1-1714168309951.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%8C%89%E4%BD%8F%20S1-ISP%20%E6%8C%89%E9%92%AE%EF%BC%8C%E5%90%8C%E6%97%B6%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E6%8F%92%E5%85%A5%20P9%3C%2FP%3E%3CP%3E%EF%BC%88%E5%8F%AA%E6%9C%89%E5%9C%A8%20RESET%20%E6%9C%9F%E9%97%B4%E6%8C%89%E4%B8%8B%20S1-ISP%20%E6%97%B6%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%89%8D%E4%BC%9A%E6%BF%80%E6%B4%BB%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%20Windows%2011%20Pro%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%97%B6%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E5%90%8C%E4%B8%80%E7%A1%AC%E4%BB%B6%EF%BC%88%E5%90%8C%E4%B8%80%20PC%20USB%20%E7%AB%AF%E5%8F%A3%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%99%9A%E6%8B%9F%20Windows%2010%20Pro%EF%BC%8Cblhost.exe%20%E6%98%AF%E5%90%A6%E8%83%BD%E6%AD%A3%E7%A1%AE%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%9C%A8%E8%BF%90%E8%A1%8C%20Windows%2011%20Pro%20%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E5%A4%8D%E5%88%B6%E9%97%AE%E9%A2%98...%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%85%8B%E5%8A%AA%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%E6%82%A8%E7%9A%84%E5%9B%BE%E5%83%8F%E7%A1%AE%E8%AE%A4%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20ISP%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20LINUX%20%E7%B3%BB%E7%BB%9F%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BD%A0%E6%8A%8A%E6%9D%BF%E7%BD%AE%E4%BA%8E%20ISP%20%E6%A8%A1%E5%BC%8F%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%20LPC55s69%20%E4%B8%8A%E7%94%A8%20HS-USB%20(P9)%20%E5%92%8C%20ISP%20%E6%8C%89%E9%92%AE%20(S1)%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%20%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275969i292B4ECF3569B09C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Pavel_Hernandez_0-1714079479432.png%22%20alt%3D%22Pavel_Hernandez_0-1714079479432.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1855017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%20PID%20%E5%8F%82%E6%95%B0%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%B8%A4%E6%AC%A1%E6%B5%8B%E8%AF%95%EF%BC%9A%20%20%E6%97%A0%E5%8F%98%E5%8C%96%2F%E9%97%AE%E9%A2%98%E7%9B%B8%E5%90%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1714068985565.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1714068985565.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275936iD2E74C78E428B63C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1714068985565.png%22%20alt%3D%22kt_0-1714068985565.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_1-1714068998365.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_1-1714068998365.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275937i2DE1DB9E37C11AD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_1-1714068998365.png%22%20alt%3D%22kt_1-1714068998365.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%85%8B%E5%8A%AA%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%E8%87%AA%E5%B7%B1%E8%BF%99%E8%BE%B9%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%84%B6%E5%90%8E%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E7%9C%8B%E5%88%B0%E4%BD%A0%E5%9C%A8%20PID%20%E9%83%A8%E5%88%86%E6%BC%8F%E6%8E%89%E4%BA%86%E4%B8%80%E4%B8%AA%200%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%200x0020%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%AE%89%E8%A3%85%20SPSDK%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E5%A4%A7%E8%87%B4%E7%9B%B8%E5%90%8C--%E8%A7%81%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%B1%8F%E5%B9%95%E8%BD%AC%E5%82%A8%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Enxpdevscan%20%E5%91%BD%E4%BB%A4%E8%83%BD%E5%A4%9F%E6%89%BE%E5%88%B0%20LPC55S66%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FLI%3E%3CLI%3Eblhost%20%E5%91%BD%E4%BB%A4%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E9%80%9A%E4%BF%A1%EF%BC%88%E8%BF%99%E9%87%8C%E6%98%AF%E7%AE%80%E5%8D%95%E7%9A%84%20RESET%20%E5%91%BD%E4%BB%A4%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kt_0-1714030318170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kt_0-1714030318170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275795iA8CD409E0D7846CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kt_0-1714030318170.png%22%20alt%3D%22kt_0-1714030318170.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E4%B8%80%E7%A7%8D%E6%AF%94%E5%AE%89%E8%A3%85%20Python%20%E8%A7%A3%E9%87%8A%E5%99%A8%20%2B%20SPSDK%20%E4%BB%A3%E7%A0%81%E5%8C%85%20%E2%80%9C%E6%9B%B4%E7%AE%80%E5%8D%95%E2%80%9D%20%E7%9A%84%E5%B7%A5%E5%85%B7%E2%80%94%E2%80%94%E8%BF%99%E9%87%8C%E7%9A%84%20blhost.exe%20%E9%9D%9E%E5%B8%B8%E5%AE%8C%E7%BE%8E%E3%80%82%3C%2FP%3E%3CP%3E%E9%9C%80%E8%A6%81%E8%AF%A5%E5%B7%A5%E5%85%B7%E6%9C%89%E4%B8%A4%E4%B8%AA%E7%94%A8%E9%80%94%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E7%94%9F%E4%BA%A7%E7%BA%BF%E4%B8%8A%E7%94%A8%E4%BA%8E%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E3%80%81%E8%AF%BB%E5%87%BA%20UUID%20%E7%AD%89%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%9C%A8%E6%B6%88%E8%B4%B9%E8%80%85%E5%AE%A2%E6%88%B7%2F%E4%BA%A7%E5%93%81%E7%BB%B4%E4%BF%AE%E4%B8%AD%E5%BF%83%E8%BF%9B%E8%A1%8C%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%AF%94%20SPSDK%20%E6%9B%B4%E7%AE%80%E5%8D%95%E7%9A%84%E5%B7%A5%E5%85%B7%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-smiling-eyes%22%20title%3D%22%3Asmiling_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E9%97%AE%E9%A2%98%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%90%A6%E4%B8%8E%20Windows%2011%20%E6%9C%89%E5%85%B3%EF%BC%8C%E8%BF%98%E6%98%AF%E9%9C%80%E8%A6%81%E6%9F%A5%E6%89%BE%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%9A%E5%9C%A8%20Windows%2011%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%20blhost.exe%20%E4%BD%95%E6%97%B6%E6%9B%B4%E6%96%B0%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%85%B6%E4%BB%96%E9%80%9A%E8%BF%87%20USB%20%E6%9B%B4%E6%96%B0%20LPC55xxx%20CPU%20%E5%9B%BA%E4%BB%B6%E7%9A%84%E7%AE%80%E5%8D%95%E7%A8%8B%E5%BA%8F%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%9A%20%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3EPS.%3A%20%E6%88%91%E4%BB%AC%E5%BA%94%E7%94%A8%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%20LPC55S69-EVK%20%E5%92%8C%20LPC55S66%20%E4%B9%9F%E5%AD%98%E5%9C%A8%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%20Knud%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20blhost%20on%20PC%20running%20Windows%2011%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E5%8F%AB%E5%B8%95%E7%BB%B4%E5%B0%94%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%BA%E6%82%A8%E7%9A%84%E6%A1%88%E4%BE%8B%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%20SPSDK%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E7%A7%8D%E6%9C%80%E6%96%B0%E7%9A%84%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%AE%83%E5%B0%86%E5%A4%A7%E9%87%8F%E5%B7%A5%E5%85%B7%E9%9B%86%E6%88%90%E5%88%B0%E4%B8%80%E4%B8%AA%E7%BD%91%E7%AB%99%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fspsdk.readthedocs.io%2Fen%2Flatest%2Fusage%2Finstallation.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%AE%89%E8%A3%85%E6%8C%87%E5%8D%97%20-%20SPSDK%20%E6%96%87%E6%A1%A3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
