bit 0 LPC_CGU->PLL1_STAT change
1,380 次查看
gustavomuro
When the processor start, the bit 0 of LPC_CGU->PLL1_STAT change betwen 1 and 0.
This cause the function Chip_Clock_GetRate(CLK_MX_MXCORE) return 0 because Chip_Clock_GetMainPLLHz() return 0.
What time recommend waiting for it to stabilize?
Thanks!
标签 (2)
1,280 次查看
kerryzhou
Hi Gustavo,
   Could you please tell us what the chip you are using now?
   Then we can help you to check it or find a code for your reference .
Waiting for your reply!
Kerry
