anonymous git clone not working
lpcware
Content originally posted in LPCWare by robotechsrl on Fri Jan 11 03:05:38 MST 2013
$ git clone http://git.lpcware.com/lwip_lpc.git
Cloning into 'lwip_lpc'...
fatal: http://git.lpcware.com/lwip_lpc.git/info/refs not found: did you run git update-server-info on the server?
What's the right URL for git repositories? As nothing I tried seems to work...
I also searched this site for instructions about how to use the repositories, but no luck.
How am I supposed to get the source code from git?
lpcware
Content originally posted in LPCWare by robotechsrl on Mon Jan 14 03:58:47 MST 2013
It's working now.
Thank you
lpcware
Content originally posted in LPCWare by lpcadmin on Fri Jan 11 11:17:08 MST 2013
The repos should be back up now via HTTP clone. Sorry about the issues.
lpcware
Content originally posted in LPCWare by lpcadmin on Fri Jan 11 10:32:29 MST 2013
thanks, will look into this today and fix.
lpcware
Content originally posted in LPCWare by jnewell88 on Fri Jan 11 09:49:56 MST 2013
Seems like the GIT repository is messed up.
The zip files are located here,
http://savannah.nongnu.org/projects/lwip/
just go to download area after clicking link
~Josh
