anonymous git clone not working
1,769 次查看
lpcware
Content originally posted in LPCWare by robotechsrl on Fri Jan 11 03:05:38 MST 2013
$ git clone http://git.lpcware.com/lwip_lpc.git
Cloning into 'lwip_lpc'...
fatal: http://git.lpcware.com/lwip_lpc.git/info/refs not found: did you run git update-server-info on the server?
What's the right URL for git repositories? As nothing I tried seems to work...
I also searched this site for instructions about how to use the repositories, but no luck.
How am I supposed to get the source code from git?
4 回复数
1,755 次查看
lpcware
Content originally posted in LPCWare by robotechsrl on Mon Jan 14 03:58:47 MST 2013
It's working now.
Thank you
1,755 次查看
lpcware
Content originally posted in LPCWare by lpcadmin on Fri Jan 11 11:17:08 MST 2013
The repos should be back up now via HTTP clone. Sorry about the issues.
1,755 次查看
lpcware
Content originally posted in LPCWare by lpcadmin on Fri Jan 11 10:32:29 MST 2013
thanks, will look into this today and fix.
1,755 次查看
lpcware
Content originally posted in LPCWare by jnewell88 on Fri Jan 11 09:49:56 MST 2013
Seems like the GIT repository is messed up.
The zip files are located here,
http://savannah.nongnu.org/projects/lwip/
just go to download area after clicking link
~Josh
