Where can I find example project for OM13500A
1,394 次查看
highrice
I'm planning to use PCA8537AH for my prototype. I found there's OM13500A evaluation board(User manual: UM10744) and example code is provided but cannot find where it is.
I've installed LPCXpresso. Opened few LPCOpen zip files but had no luck.
Thank you!
1,320 次查看
TomasVaverka
Hi Seungwon,
Unfortunately NXP does not provide the code running in the LPC1115 on the OM13500A demo board.
The only available software code example for the PCA8537 is the one that you can find in section 4 (page 10) of the UM10744.
Tomas
1,320 次查看
highrice
Hi Tomas,
I should write my own code then.
Thank you for the information!
Kind regards,
Seungwon
