Values of Reserved Bits in CMPA/CFPA Registers
2,831 次查看
LucianA
Hello!
I have a question regarding how to set Reserved bits in the following registers
DCFG_CC_SOCU_NS_PIN (bits 14:10, and
DCFG_CC_SOCU_NS_DFLT (bits 15:10, 8).
In User Manual, for SECURE_BOOT_CFG (page 153), PRINCE_BASE_ADDR (page 154) etc
it is specified that Reserved Bits should be filled with zeros.
Is that also mandatory for Reserved Bits in DCFG_CC_SOCU_NS_PIN, DCFG_CC_SOCU_NS_DFLT?
Thank you!
2,758 次查看
ZhangJennie
HI LucianA
If you don't want to enforce UUID checking, please leave these bits as default (0)
Hope this helps,
Jun Zhang
4 回复数
2,818 次查看
ZhangJennie
HI LucianA
To resolve your problem, please let me know,
- your chip part number
- document screenshot of where you concerned about.
Thanks for your cooperation,
Jun Zhang
2,812 次查看
LucianA
Hi Jennie,
According to "LPC55S6x_LPC55S2x_LPC552x Protected Flash Region v1.3.xlsx"
DCFG_CC_SOCU_NS_PIN and DCFG_CC_SOCU_NS_DFLT registers have the same format for all those families.
However, I'm particularly interested for LPC5528 device.
It's a must to write zeros in the Reserved Bits marked in red in the attached picture (DCFG_CC_SOCU_NS_PIN[14:10] and DCFG_CC_SOCU_NS_PIN[8])  ?
Thank you!
2,759 次查看
ZhangJennie
HI LucianA
Hope this helps,
Jun Zhang
2,751 次查看
LucianA
Thanks Jennie,
I will keep all reserved bits on default values (zeros).
