USB connect state
USB connect state
2,380件の閲覧回数
googcheng
how to check USB connect state for lpc1343 at chip endpoint?
when will it enter USB interrupt handler?
what does (*rom)->pUSBD->isr(); do?
ラベル(2)
3 返答(返信)
2,160件の閲覧回数
kerryzhou
Hi Jay,
   What the USB type you are using?
   Normally, you can check it in the PC device manager usb controllers item, if your USB is useful, it will be list in the device mange item.
Kerry
2,160件の閲覧回数
googcheng
connect lpc1343 dali master to PC,  i want to check the connect state within lpc endpoint code,
like the "Get Device Status" command.  is there a connect/disconnect interrupt or a state check function?
2,160件の閲覧回数
kerryzhou
Hi Jay,
   About the dali master, you can refer to our application note and the according example:
https://www.nxp.com/downloads/en/software/LPC11xx_LPC13xx_DALI_DevKit_AN11175.zip
Wish it helps you!
Kerry
