[Solved] WDOSC not starting
753 次查看
Content originally posted in LPCWare by MarcVonWindscooting on Sun May 11 15:22:10 MST 2014
I want to run a LPC812 at WDOSC / n to get an idea of power consumption at low frequencies.
Since my program kept freezing, when switching the clock to WDOSC, I output WDOSC to CLKOUT.
Outcome: I can't get WDOSC running at all |(
What am I missing?
I configure it using WDOSCCTRL. I even switched on the WWDT bit in SYSAHBCLKCTRL which should not be needed in my opinion.
What else is needed for starting WDOSC?
SOLVED: I should search the manual using 'WD[color=#f03]T[/color]OSC  ;-)
0 回复数
