Software example for lpc43Sxx AES engine
2,469 次查看
sylvio5
Hello
Is there any code snipet or application note or project example for how to use the hardware AES engin of the LPC43S serie ?
Thank you very much
Cheers
2,120 次查看
sylvio5
Hello Soledad, thank you for your answer but as I see this application note refers to a library that doesn't use the hardware engine of the LPC43Sxx. What I would like to do is using this hardware engine.
Is there any application note or code example for that ?
2,120 次查看
sylvio5
Is there really any example neither AN for using the hardware AES engine of LPC S series ???
2,120 次查看
soledad
Please check the AN11241, this application note discusses an implementation of an AES encryption algorithm according to the FIPS197 standard.
http://cache.nxp.com/documents/application_note/AN11241.zip?fsrch=1&sr=1&pageNum=1
Sol
