Secondaery bootloader on LPC11U67
Guy_mego
Hi All,
I'm new with writing a secondary bootloader to my LPC11U67.
I was able to erase the flash, nut when I came to write to an address the function
Chip_IAP_CopyRamToFlash retutns me a value of 6 - ERR_ISP_COUNT_ERROR which means:
Byte count is not multiple of 4 or is not a permitted value.
I was trying to solve it by changing the destination address, the buffer i sent but there is no change, still get the same error.
Can anyone assist me to understand what this error means and how to solve it.
Thanks in advance.
xiangjun_rong
The number of Byte must be 256, 512,1024,2048, otherwise, the COUNT_ERROR will happen.
Pls check the number of byte parameter
Hope it can help you
XiangJun Rong
xiangjun_rong
XiangJun Rong
Guy_mego
It works.
Thanks a lot.
