SDRAM strange problem!
2,590件の閲覧回数
behnamshakibafa
Hi everybody
I designed new PCB with exact same schematic with my avaluation board, but got in trouble with SDRAM.
the K4S511632 chip is used. I tried a test code. what I can see is that error in writing or reading with a constant pattern. I write data on all space, then the on reading, every 4 32bit data I read, one time has error and every time error is same. I wrote 0xBBCCDDEE and I read 0x0xBBCCBBCC!
Can any one help me on this?
     /* Writing */
     for (i=0; i<SDRAM_SIZE/4; i++)
       *char_wr_ptr++ = 0xEE;
       *char_wr_ptr++ = 0xDD;
       *char_wr_ptr++ = 0xCC;
       *char_wr_ptr++ = 0xBB;
       /* Verifying */
     wr_ptr = (uint32_t *)SDRAM_BASE_ADDR;
       for ( i= 0; i < SDRAM_SIZE/4; i++ )
          if ( *wr_ptr != 0xBBCCDDEE )     /* be aware of endianess */
                 /* byte comparison failure */
               err++;
          wr_ptr++;
Behnam
ラベル(3)
タグ(2)
2,392件の閲覧回数
avt
This forum is for LPC parts not Kinetis. Suggest that you post to a more appropriate forum.
2,392件の閲覧回数
behnamshakibafa
Please help me on this dudes
2,392件の閲覧回数
avt
