lpc936
lpc936
cargr
hello, my name is carlos and start this comment for help, I have a programmer for a p89lpc936 icp and can record all the micro but I can not read it. the only thing I've found online about icp mode is fmcon, fmdata and fmadreesl / h. I do not know any command to read both flash and EEPROM. I am initiating me in LPCS.
in Spanish:hola, mi nombre es carlos e inicio este comentario para pedir ayuda, tengo un programador icp para un p89lpc936 y puedo grabar todo el micro pero no puedo leerlo. lo unico que he encontrado por internet sobre el modo icp es fmcon,fmdata y fmadreesl/h. no conozco ningun comando que lea tanto la flash como la eeprom. estoy iniciandome en los lpcs. gracias.
vicentegomez
Please be aware that all the LPC9xx is obsolete and is no longer available. Please let me know if you want information about other device.
Have a good day
Vicente Gomez
cargr
Ok, thanks.
El 4 nov 2016, a las 20:54, vicentegomez <[email protected]> escribió:
NXP Community
Re: lpc936
reply from Vicente Gomez Salazar in LPC - View the full discussion
Have a good day
Vicente Gomez
Reply to this message by replying to this email, or go to the message on NXP Community
Start a new discussion in LPC by email or at NXP Community
Following Re: lpc936 in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
