SDK_2.7.0::LPCXpresso54S018M fails to compile
3,319件の閲覧回数
belmontbob59
Hello, I downloaded the latest version of the SDK (2.7.0) for Windows, and KEIL IDE. When I compile keyboard2mouse USB example, I get the errors below. I do not get any error when building keyboard2mouse on older SDKs 2.6.0 and 2.5.0.
please advise.
*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'keyboard2mouse_bm debug'
compiling usb_host_framework.c...
Fatal error: C3900U: Unrecognized option '-fno-common'.
Fatal error: C3900U: Unrecognized option '-fdata-sections'.
Fatal error: C3900U: Unrecognized option '-ffreestanding'.
Fatal error: C3900U: Unrecognized option '-fno-builtin'.
Warning: C3910W: Old syntax, please use '-M'.
Warning: C3910W: Old syntax, please use '--thumb'.
compiling usb_host_ohci.c...
compiling clock_config.c...
compiling usb_device_dci.c...
compiling pin_mux.c...
compiling fsl_common.c...
compiling device_mouse.c...
compiling usb_device_hid.c...
compiling usb_host_hub_app.c...
compiling usb_host_hci.c...
compiling board.c...
compiling usb_device_ch9.c...
compiling usb_host_ip3516hs.c...
compiling usb_host_devices.c...
compiling fsl_usart.c...
compiling usb_device_lpcip3511.c...
compiling host_keyboard.c...
compiling usb_device_class.c...
compiling usb_device_descriptor.c...
compiling fsl_clock.c...
compiling app.c...
compiling usb_host_hub.c...
compiling usb_host_hid.c...
compiling fsl_gpio.c...
compiling fsl_flexcomm.c...
compiling fsl_power.c...
compiling fsl_reset.c...
compiling fsl_emc.c...
compiling system_LPC54S018M.c...
assembling startup_LPC54S018M.s...
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(1): error: A1167E: Invalid line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(2): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(3): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(4): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(5): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(6): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(7): error: A1167E: Invalid line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(8): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(9): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(10): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(11): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(12): error: A1159E: Label missing from line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(13): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(14): error: A1167E: Invalid line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(15): error: A1163E: Unknown opcode Version: , expecting opcode or Macro
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(16): error: A1167E: Invalid line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(18): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(19): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(20): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(22): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(23): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(24): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(26): error: A1167E: Invalid line start
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(27): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(28): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(29): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(30): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(31): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(32): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(33): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(34): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(35): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(36): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(37): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(38): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(39): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(40): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(41): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(42): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(44): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(45): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(46): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(47): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(48): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(49): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(50): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(51): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(52): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(53): error: A1137E: Unexpected characters at end of line
../../../../../../devices/LPC54S018M/arm/startup_LPC54S018M.s(54): error: A1137E: Unexpected characters at end of line
compiling fsl_assert.c...
compiling fsl_debug_console.c...
compiling fsl_str.c...
compiling usart_adapter.c...
compiling serial_manager.c...
compiling serial_port_uart.c...
compiling generic_list.c...
compiling fsl_os_abstraction_bm.c...
"debug\keyboard2mouse_bm.out" - 50 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:02
ラベル(2)
3 返答(返信)
2,932件の閲覧回数
ZhangJennie
Hi bob
I just build the sdk2.7.0 usb project with MDK2.29. No build error.
See attached video
Please check if your Keil LPC54018M pack are well installed.
if still have error. redownload the SDK for Keil MDK and test it on another PC. if you experience the same issue.
Have a nice day
Jun Zhang
2,932件の閲覧回数
belmontbob59
Thank you for your reply. you are using MDK5.29 right ? You wrote MDK2.29.
I am using MDK5.22 which works well with SDKs 2.5.0 and 2.6.0. Unfortunately I can't upgrade to MDK5.29.
2,932件の閲覧回数
ZhangJennie
Hi bob belmont
It's typo. Yes, I mean MDK5.29.
According to SDK2.7.0 release note under SDK install folder. it was only tested under below platform.
Thus the lower version MDK is not supported.
If you use MDK5.22, please use the low version SDK instead.
Have a nice day
Jun Zhang
