SDIO interrupt not detected
2,192 次查看
PIHL
I try to port WHD Library from Cypress to use CYW43012 with LPC54607.
I use an interrupt mode for communication, but LPC MCU is not running SDIO_IRQHandler function. In the init of system I have a part of code for interrupt registration:
NVIC_SetPriority(SDIO_IRQn, 5U);
NVIC_EnableIRQ(SDIO_IRQn);
I was looking for interrupt on DATA1 line, but was not able to detect it with a scope.
Is there any additional configuration needed to run SDIO_IRQHandler funtion after interrupt?
Piotr
标记 (5)
2,186 次查看
ZhangJennie
Does WHD Library from Cypress is included in MCUXpresso SDK? If not, we can't test it.
I suggest you referring and comparing your code with our demo
{MCUXpresso SDK folder}\boards\lpcxpresso54608\sdmmc_examples\sdio
Best Regards
Jun Zhang
2,187 次查看
ZhangJennie
Best Regards
Jun Zhang
