SATA interface design
1,451 次查看
daramsreedevi
I need to design a board with ethernet,SATA,USB interfaces.which one i should go CortexM4 or processor model.This will be used for data storage.
1,308 次查看
jeremyzhou
Hi daram sreedevi,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
There are none of NXP Cortex-M core MCU integrates the SART controller, however the PowerQUICC™ Processors are able to do.
Hope this helps.
TIC
