 * @briefReturn number of bytes in the ring buffer that can be retrieved in ascending linear order from tail
 * @paramRingBuff: Pointer to ring buffer
 * @returnNumber of bytes in linear order
int RingBuffer_GetCountLinear(RINGBUFF_T *RingBuff)
return MIN(RingBuffer_GetCount(RingBuff),RingBuff->count - RB_INDT(RingBuff));
 * @briefReturn pointer to tail
 * @returnPointer to tail
STATIC INLINE void* RingBuffer_GetTail(RINGBUFF_T *RingBuff)
return RingBuff->data+RB_INDT(RingBuff);
 * @briefMove tail pointer by n bytes (deletes n oldest bytes)
 * @paramn: number of bytes to be deleted
 * @returnNumber of bytes deleted
int RingBuffer_MoveTail(RINGBUFF_T *RingBuff, int n)
if (RingBuffer_GetCount(RingBuff) < n) n=RingBuffer_GetCount(RingBuff);
RingBuff->tail+=n;
return n;
// if the buffer is not empty, then stuff as much as possible into the LWIP buffers again
if (!RingBuffer_IsEmpty(&out.rb))
// get number of bytes that can be copied/accessed in ascending order
n=MIN(tcp_sndbuf(lwip_dbg.accepted), RingBuffer_GetCountLinear(&out.rb));
// copy data directly from ringbuffer memory to LWIP memory
tcp_write(lwip_dbg.accepted, RingBuffer_GetTail(&out.rb), n, TCP_WRITE_FLAG_COPY);
// free ringbuffer memory
RingBuffer_MoveTail(&out.rb, n);
