RDDI-DAP Error,Error: Flash Download failed - "Cortex-M4"
11,138件の閲覧回数
haiboyang
Hi friend;
I am trying to build and download sdcard_fatfs demo code, could pass build, but fail to flash download in Keil enviroment, following are the errors, appreciate any comments.
I attached my debug configuration picture.
Load "debug\\sdcard_fatfs.out"
Erase Done.
Programming Done.
RDDI-DAP Error
Haibo
8,468件の閲覧回数
kerryzhou
Hi Haibo Yang,
    Please tell me what the board and the code you are using? Is the official board?
   Please also check the MDK configrations:
  Whether in Utilities also have he debugger configurations?
  In this picture:
Please select the lower max clock and try again.
  If you still have problem, please tell me the board, the code and the MDK version which you are using, then I will try it on my side.
Kerry
