RDDI-DAP Error,Error: Flash Download failed - "Cortex-M4"
11,104 次查看
haiboyang
Hi friend;
I am trying to build and download sdcard_fatfs demo code, could pass build, but fail to flash download in Keil enviroment, following are the errors, appreciate any comments.
I attached my debug configuration picture.
Load "debug\\sdcard_fatfs.out"
Erase Done.
Programming Done.
RDDI-DAP Error
Haibo
8,434 次查看
kerryzhou
Hi Haibo Yang,
    Please tell me what the board and the code you are using? Is the official board?
   Please also check the MDK configrations:
  Whether in Utilities also have he debugger configurations?
  In this picture:
Please select the lower max clock and try again.
  If you still have problem, please tell me the board, the code and the MDK version which you are using, then I will try it on my side.
Kerry
