config_tab
config_tab
ianbenton
Senior Contributor I
Just idle curiosity when looking at the _dis file. . . .
The compiler produces a large (about 1k) table called "config_tab". What is it for?
Why does it compile the aeabi_div routines ?
Labels (2)
kerryzhou
Hi Ian Benton,
   What's the chip and what's the code you are using?
   Please give us more details, then I can help you to check it.
   Waiting for your reply!
Kerry
ianbenton
The last one was easy - it compiles the aeabi_div routines because it uses them in
<Chip_IRC_SetFreq>, but I'm still curious about config_tab
