Question, LPC183x reference board
2,281件の閲覧回数
SLICE
Dear team,
My customer is investigating if they can use NXP/LPC183x for their products.
They want to use its two USB ports as High Speed.
And they want to obtain EVB or its schematic which LPC183x is used with TWO USB High Speed as reference.
They already found your LPC1837 Xplorer board can support one USB High Speed and one USB Full Speed. But they want to use two USB High Speed ports.
Do you know what board supports two USB high speed ports?
Miyamoto
4 返答(返信)
2,088件の閲覧回数
jeremyzhou
Hi Masamichi Miyamoto,
for the opportunity to serve you.
Unfortunately, there are no boards that support two USB High Speed port.
Hope this is clear.
TIC
2,088件の閲覧回数
SLICE
Hi jeremyzhou‌
Thanks for your support.
Any reference designs? No need to be checked for its actual behaviour.
Miyamoto
2,088件の閲覧回数
SLICE
Hello jeremyzhou‌
I found the AN11309 application note which describes about high-speed USB.
Is it helpful for using two high-speed USBs?
BR,
Miyamoto
2,088件の閲覧回数
jeremyzhou
Thanks for your reply.
1) Is it helpful for using two high-speed USBs?
-- Yes, it's very helpful.
TIC
