Programming a LPC55S16-EVK
randylee
Contributor V
How do I flash an LPC55S16-EVK without MCUexpresso?  I've got a hex file that I need to send to others and have them flash their boards..
converse
Senior Contributor V
You didn’t mention that you wanted to use SWD...
if you boards have Lpc-link2 on board, the you could program the JLink image (using lpcscrypt) and then use Jflash or jflash-lite - but you need to check the license as you may need to purchase the license (or not - I don’t know)
randylee
Contributor V
yup, works! Instant J-Link Lite board.  Using J-Flash lite I can program the board up.
converse
randylee
Contributor V
Flashmagic doesn't look like it can program that part?   It appears to want the bootloader running on a serial port or USB port.
The dev board has what is essentially a LPC Link2 on it connected to the SWD interface of the 55S16.
Maybe I'm wrong, but it doesn't look like FlashMagic knows about JTAG/SWD interfaces on most parts....
converse
randylee
Contributor V
OK, I'll buy that approach.... anyone know if the LPC55S16-EVK debug interface is close enough to a LPC-Link2 to not brick it by reflashing it to a Jlink?
converse
Well it took me 5 seconds to find that LPC55S16-EVK debug is LPC-Link2... look at the datasheet
