Power consumption of LPC4357JBD208
929 次查看
dharitri
Dear All,
I am using LPC4357JBD208 controller in our design. Need to calculate the power consumption for the IC. Is there any power calculator available for the same... ???
Thanks in Advance!!!
Dharitri
842 次查看
soledad
Unfortunately we don't have a power calculator available for this device, howeevr I suggest to check the AN11853 application note as reference, this application note introduces the various low power modes of the LPC18x0, the steps required to enter the low power modes, wake-up implementation, and helpful hints to reduce power consumption.
This application note also provides a software example to enter the low power modes, and demonstrates how to measure the power consumption using the Keil MCB1800 board.
https://www.nxp.com/docs/en/application-note/AN11853.zip
Sol
