Part Marking for part number LPC11U24FBD48/40EL
1,418 次查看
williamwee
Could you help to confirm the part marking for Part LPC11U24FBD48/40EL?
One of my customer received part's marking as LPC11U24F/401, is this the correct part ?
Could you explain the marking received as 401 instead of 40EL ?
1,393 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, the image below shows the minimum number of pieces that you can buy.
Pavel
1,394 次查看
Pavel_Hernandez
Pavel
