PC-LPCLink2 communication
3,643 次查看
navidfanaee
Hi everybody
I am totally new to LPCLink2. I am programming LPCLink2 so it can communicate with PC through USB, however; i do not know how to program it that I can use the USB. When I try to program the board using LPCScrypt the "Targetinfo" says that it only has 1MB of SPIFI which needs jumper p1 to be connected to be able to run the program, this way PC does not recognize the board USB. I think i need to program the board on memory other than SPIFI that does not need JP1 to be fitted, but i do not know how.
Thanks in advance for your responses.
标签 (2)
3,407 次查看
jeremyzhou
According to your statement, I think you want to update the firmware of the LPC-link2 board, so I've attached LPC-Link2 Debug Probe Firmware Programming, the document will guide you how to do it.
TIC
3,407 次查看
navidfanaee
Thanx Jeremyzhou for your response. No in fact I want to send and receive data through USB protocol. however; PC does not recognize USB device with JP1 fitted, it shows USB as lpc 18xx generic usb.
thanks in advance.
3,407 次查看
jeremyzhou
Hi ,
Thanks for your reply.
To be honest, I'm a bit confused about your purpose, can you clarify it again?
TIC
