OM13085 debug board lost firmware
1,777 次查看
shelbyteknologi
I have a OM13085 and after programming the example blinky it seems to have lost the firmware on the 11U35.  I've tried to jumper J4 to put it in ISP mode but it doesn't respond.  Any idea how I can recover the firmware on the debug part of the board?
1,670 次查看
shelbyteknologi
I'm trying to get the mbed firmware back so that when I plug in the board it mounts as a drive but can't find the original firmware.
1,670 次查看
Carlos_Mendoza
Hi James,
You can download the firmware for the LPC11U35 debug probes from this link:
Firmware and drivers for LPC11U35 debug probes
and you can use the following document as reference on how to update the firmware:
https://community.nxp.com/docs/DOC-335453
Hope it helps!
Carlos Mendoza
Technical Support Engineer
