Microcontroller LPC32x0
3,544 次查看
justinvil1103
Hi All,
Would anyone help me identify the highlighted values below? I am assuming 0 = not supported and 1 = supported, am I correct?
Thank you,
Willer
3,537 次查看
Pavel_Hernandez
I checked out this MCU individually and confirm that your assumption is correct.
Pavel
5 回复数
3,529 次查看
frank_m
Senior Contributor III
I would interpret the 0/1 as the number of interfaces in the specific variant, which would amount to the same.
For serial interfaces like UART, SPI, I2C and CAN, these numbers are usually in the range 2..8.
3,538 次查看
Pavel_Hernandez
Pavel
3,539 次查看
Pavel_Hernandez
Could you tell me the name of the document or where did you find this? I need to review it.
Pavel
3,520 次查看
justinvil1103
3,515 次查看
Pavel_Hernandez
That means the quantity too.
Pavel
