Microcontroller LPC32x0
3,419件の閲覧回数
justinvil1103
Hi All,
Would anyone help me identify the highlighted values below? I am assuming 0 = not supported and 1 = supported, am I correct?
Thank you,
Willer
3,412件の閲覧回数
Pavel_Hernandez
I checked out this MCU individually and confirm that your assumption is correct.
Pavel
5 返答(返信)
3,404件の閲覧回数
frank_m
Senior Contributor III
I would interpret the 0/1 as the number of interfaces in the specific variant, which would amount to the same.
For serial interfaces like UART, SPI, I2C and CAN, these numbers are usually in the range 2..8.
3,413件の閲覧回数
Pavel_Hernandez
Pavel
3,414件の閲覧回数
Pavel_Hernandez
Could you tell me the name of the document or where did you find this? I need to review it.
Pavel
3,395件の閲覧回数
justinvil1103
3,390件の閲覧回数
Pavel_Hernandez
That means the quantity too.
Pavel
