MCUXpression IDEjava.io.FileNotFoundException
2,293件の閲覧回数
Guillaume_B
Hello
I use MCUXpresso IDE to programm a microcontroller (Thingstream starterkit - MKL27Z4 with LPC2 programmer). I created a new project (I take an exemple project so there is no mistake in it). Building the project and debugging works well but when I try to run the code, I have this error in the console : java.io.FileNotFoundException: C:\ProgramData\MCUXpressoIDE_11.2.1_4149\ide (Access denied)
I already check the target file to be sure that it is accessible - it is accessible for reading and writing for all users (I am on Windows 10)
Can you help me ? Thank you
3 返答(返信)
2,284件の閲覧回数
converse
Senior Contributor V
How are you trying to ‘run’ the code? What steps are you following. In fact, what are you even expecting to ‘run’?
2,274件の閲覧回数
Guillaume_B
I connected the microcontroller to my pc and I click on "Run" (the green triangle).
I expected the code to be executed (the exemple code should just create a variable and print something in the console).
2,246件の閲覧回数
converse
Suggest you read this:
https://mcuoneclipse.com/2014/10/04/emulating-eclipse-run-with-debug-configuration/
[This is rather old, and things have changed a little in MCUXpresso, but the principle still holds]
