LPCXpresso v8.2.2 JLinkGDBServer LPC1765
1,915 次查看
zp_casper
I have followed
https://www.segger.com/products/debug-probes/j-link/technology/ides/nxp-lpcxpresso-pro-edition/
but  unfortunately  i get  error   on  LPCXpresso
Failed to execute MI command:
-data-disassemble -s 3735928558 -e 3735928646 -- 3
Error message from debugger back end:
Cannot access memory at address 0xdeadbeee
see  attached  file ? please advice
1 回复
1,905 次查看
converse
Senior Contributor V
Looks like a problem in your code. The PC is at address 0xdeadbeef, which obviously doesn’t exist, and is normally used to initialise some memory areas to indicate a problem. I would guess you have a problem in your startup code.
so to confirm, this is NOT a problem with ‘presso or Jlink, but a problem in your code.
