LPC845 port byte write
2,182 次查看
gschelotto
Any hint to write a port byte GPIO output on LPC845? I'm not able to find it in the SDK examples.
regards,
gaston
2,169 次查看
gusarambula
Hello Gaston,
The closest example available would be the gpio_led_output, available on the latest SDK, under drivers_examples, which may serve at least as a starting point.
You may import it using the Import SDK example under the Quickstart Panel on MCUXpresso.
My apologies for the inconvenience.
Gustavo
2,170 次查看
gusarambula
Hello Gaston,
Gustavo
